Enables the DHCP relay agent option (option 82) checking in the server-originated packets.
N/A.
When the option 82 is present in the packet, the MAC address specified in the remote-ID sub-option is the switch system MAC address. If the check fails, the packet is dropped.
When option 82 is not present in the packet, the DHCP packet is forwarded with no modification.
To disable this check, use the following command:
unconfigure ip-security dhcp-snooping information checkThe following command enables DHCP relay agent option checking:
